Tv antennas and Tv reception
REMOVE the Splitter. . A way to 'Prove Out' reception is to run a known to be good RG-6 coax Direct from the antenna DIRECT to the Tv , No couplers , No splitters , No nothing. One length of coax Direct from the Antenna to the Tv. If there is RG-59 coax in the walls then it has been there for a Long Time. RG-6 will transfer the signal any where through out the house. You can also move the Tv close to the antenna as a test.
