Old 4-Mar-2012, 5:44 AM   #8
Ideally, an outdoor mast would be connected to the electrical service ground using a #10 gauge copper wire (or larger)... the most effective ground connection is short and direct, if bends are needed, they are not sharp.
Ideally, the coax down-lead would be run close to the electrical service ground. There, a ground-block would be connected to the service ground using a #10 gauge copper wire (or larger).
