Tv antennas and Tv reception
The HD7696P antenna will receive some stations through the back side of the antenna. The , > , shaped UHF reflectors of the HD7696P antenna can be removed for a little better UHF reception through the back side of the antenna. However removing the reflectors reduces the forward gain of the antenna. . If you will like to experment and do it different then install a Antennas Direct DB4e or Antenna Craft U8000 aimed at about 228 degree magnetic compass. Try the the reception with the reflector screen on and off of the DB4e. And try the reception with the reflector rods on and off of the U8000. To remove the reflector rods from the U8000 , drill out the rivets that hold the metal clips that hold the reflector rods in place. To put the rods back on use bolts and nuts.
