Old 3-Mar-2012, 5:37 PM   #13
No static at all
No static at all's Avatar
Originally Posted by MisterMe View Post
Location. The primary source of multipath signals is the steel structure of your residence or of neighboring buildings. If possible, give your antenna a clear view away from metal structures.
Location will likely make the most difference. Once you experiment with the antenna on the roof, you should notice quite an improvement. The antenna you have offers more than enough multipath rejection. I have even tried the Winegard Ghost Killer here & the ANT751 works just as well.
