Old 3-Mar-2012, 3:45 PM   #12
MisterMe
Originally Posted by vader88 View Post
... I just don't understand how my cheap indoor antenna can do better though. Is there a better type of antenna to try to help with multipath problems?
There are several strategies for dealing with mult-path signals:
  • Directional antenna. By definition, multi-path signals arrive from various directions. A directional preferentially receives signals from straight ahead which may be signals from other directions too weak to affect your tuner. Among indoor antennas, the Terk HDTVi appears to be most directional.
  • Signal attenuator. Multi-path signals are almost always limited to strong signal conditions. Reflected signals are almost always weaker than the primary transmitted signal. An attenuator will reduce all signals, but may reduce the reflected signal below your tuner's reception threshold while leaving the primary signal with enough strength for your tuner.
  • Location. The primary source of multipath signals is the steel structure of your residence or of neighboring buildings. If possible, give your antenna a clear view away from metal structures.
