Old 2-Mar-2012, 11:15 PM   #2
Electron
Tv antennas and Tv reception
This recommendation is based on the tvfool radar report for 03-02-2012 for the Current Plus Pending Applications Included of Digital Tv Channels. Your location has receivable digital tv stations/channels at 4 locations around the compass. KWAB-TV 33 NBC and LATV and Telemundo . KPCB-DT 17 Religion . KTXS-TV 20 ABC and CW and This Tv . KIDB-LD 35 MyNetwork . KLST-DT 11 CBS . KSAN-DT 16 NBC. There is more then one way to set up a antenna to receive the Tv stations. One way is a antenna a preamp and a rotor , Install a Winegard HD7698P antenna with a Winegard AP2875 preamp and a Channel Master CM9521A rotor on the 35 foot tower , that would put the antenna at about 45 feet. The antenna will rotate around and receive Tv transmissions the 4 directions , Rotors however are not friendly for channel surfing , must wait for antenna to rotate. The next way ( the way that I recommend ) is a 2 antenna set up , a HD7698P antenna with a Winegard AP2875 preamp will be aimed at KSAN / KLST at about 145 degree magnetic compass. And a second antenna , a HD9095P antenna with a Winegard AP2875 preamp aimed at KTXS / KIDB at about 80 degree magnetic compass. The 2 antennas will be 2 Separate systems with separate coax going to the location of the Tv. At the location of the Tv the 2 separate coax systems will be connected to a Radio Shack # 15-1968 Remote control A/B antenna switch and the out put of the A/B switch is connected to the Tv. The hand held remote control is the Easy Life and is Friendly for Channel Surfing. With the 2 antenna set up , KWAB NBC and KPCB Religion will not be received.
