Thread: New to Antenna
Old 20-Jul-2010, 8:59 PM   #3
Reception
It will be the Winegard 7697P antenna pointed at Atlanta. Get the antenna up high , 30 feet. And you will receive all the Atlanta digital stations. Your location shows land obstructions hills ridges etc,. . Solid signal http://www.solidsignal.com has the antenna and different kinds of mountings to get the antenna up in the air. For something to play around with. A simple rods and loop (rabbit ears) antenna might get you a few stations , as always get the antennas up high , do not put them on the ground. Do not bury the antenna deep in side the house. Put the indoor antenna at an unobstructed window , no metal screen on the window that faces the television transmitters. http://forum.tvfool.com/showthread.php?t=233
