Old 2-Mar-2012, 1:56 PM   #16
No static at all
No static at all's Avatar
Have you tried raising/lowering the antenna a few inches. The antenna may be in a dead spot for ION.
Also, the signal coming from ION is weak & will likely require the antenna be aimed directly at it to make it more reliable. The signal from ION is highly directional & unfortunately not strong in your direction. The majority of their signal is directed to areas north of the transmitter.
