Tv antennas and Tv reception
Billiam please think about what you say with print. "mounted in a certain way" is a loop hole statement. Now the hoa can say , well Ok you can have have a antenna but you have mount it this "certain way" -> you have to mount it so no one can see it from the street or the antenna must be mounted behind the chimney. Or the antenna must be this way or that way. The truth is the antenna can be mounted any place that gets good clear reception at the place is of your choice. Do not use words or information that opens up loop holes. The Federal Law covers all the loop holes , however it is not a good idea to go around opening up loop holes so some one can stick a finger through and poke ya in the eye.
