Old 19-Jul-2010, 5:45 PM   #1
rwilson1206
Need New Antenna System Advice
I am helping my friend install a new antenna system on his roof. In the past tvfool has helped me get my system and I have a HBU33 (330 degrees) and CM4221 (approx 90 degrees). My friend lives near me, canal fulton, oh and I live in north canton, oh. The broadcasting signals between cleveland and youngstown are about 90 degrees apart. My setup works good, so I was just going to have him get the same thing. I have an outdoor amplifier right after I combine the antennas at the top of my tower, then I go into a 4 way splitter. He is just going to one tv so no splitter needed. Are these antennas still adequate, or is there something else you recommend. Also, he lives in a townhouse, and he does not have a chimney. Can you recommend a roof mount. I wanted to avoid penetrating the roof, but if thats what has to be done, please suggest a good roof mounted option for these two antennas, or whatever antennas you recommend. Here is a link to his signals....
http://www.tvfool.com/?option=com_wr...9fbe371b8cd06f
Thanks for the help!
rwilson1206 is offline   Reply With Quote
