Old 29-Feb-2012, 6:13 AM   #5
Electron
Tv antennas and Tv reception
It is Ok to read my recommendation , you will find the preamp that is recommended . Use a simple 2 way splitter. The power supply of the preamp will be on the input port of the splitter , Do Not connect the power supply of the preamp to one of the 2 output ports of the splitter. The preamp unit will be mounted close to the antenna. http://www.saveandreplay.com , will have all that is required to receive Tv reception. Order on line or go into the store.
