Thread: New antenna
Old 19-Jul-2010, 2:10 PM   #3
YOG
I have the coax plug in directly in my new LCD with built in tuner and i receive all of the analog channels. I am interested in getting more digital channels or stronger signal for the ones I get.
I have my antenna pointing at 110 degrees and can get all the channels with NM(dB) above 0. Although the channels with NM(dB) between 0 to +10.0 are in and out. How can I get stronger signal for these channel?
I also would like to get some local digital channels that are closer in distance but are lower in NM(dB) (Virt) 44.1, 25.1, 64.1, 57.1, 41.1, 61.1.
For best results should I have two antennas 1 pointing at 120 degrees, and 2nd pointing at 46 degrees with a booster or something that will increase these signals.
tvfool analysis
http://www.tvfool.com/?option=com_wr...9fbe73b1c44f64
Thank you,
YOG
YOG is offline   Reply With Quote
