Old 28-Feb-2012, 7:47 AM   #2
Electron
Tv antennas and Tv reception
Your location has Many Digital Channels to receive both Canada and USA. This recommendation is based on the tvfool radar report of the Current and Pending Applications Included , Digital Tv Broadcast Channels as of 02-27-2012. Install a Antennas Direct DB4e antenna with a Antennas Direct CPA-19 preamp aimed at about 195 degree magnetic compass. The Tv stations/channels that will be received are the groups of digital tv stations/channels in the green and yellow reception zones to the south and south west down to WNYO-DT UHF channel 49 MyNetwork. http://www.saveandreplay.com has the DB4e and CPA-19 preamp. And any other OTA = Over The Air , equipment you will require. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some examples of antenna mounts that most often used. 5 foot tripod mount , Eave mount , Chimney mount , Channel Master antenna mounts or Winegard antenna mounts or some other manufacture , saveandreplay will have. http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html.
