Many of the stations that are LOS (line of sight) on your TVFool report are still broadcasting in analog not digital....the digital converter box will not receive these channels unless there is a pass-thru option for analog on the box.
To look to see if you can get the analog stations, plug the antenna coax directly into the TV and see what you get...
