Old 28-Feb-2012, 5:42 AM   #7
ghz24
I'd recommend RG6 if you're running new.
I'll run a RG59 coax cable from the antenna down to the basement where I'll hook into the existing coax which was used for cable tv. The coax splits into 4 rooms.
Sounds like he wants to use the coax installed in the house maybe to avoid
install a indoor antenna at each Tv location
Which will work if you are ok with it. Except basements and foil insulation barrier possibly blocking signal.
The RCA ANT751R Outdoor Antenna is a directional antenna.
ghz24 is offline   Reply With Quote
