Old 28-Feb-2012, 4:20 AM   #2
ghz24
Just in case you didn't know
The homeowners association here does not allow outside antennas.
They can't stop you the federal government has specifically protected your rights to have an antenna (regardless of any agreement made with local authority).
But you really don't need an outdoor antenna ktps on VHF ch.8 is as far down the list as you'll get without heroic efforts (and even then the weaker signals with tropo path would have questionable reliability)
Instead of 2 antenna I'd remove the reflector from a antennas direct db4e (or similar bay type antenna).
You don't need a VHF capable antenna just UHF.
No amp signals to strong.
ghz24 is offline   Reply With Quote
