Thread: I need wisdom
Old 27-Feb-2012, 5:53 PM   #1
Jonah
I need wisdom
I have cut the cord with our cable company.
Before we did I did some research for our area (Glendale, Arizona) and saw that the RCA ANT751 antenna ought to serve my purposes well. We live in an HOA and the compact size of the ANT751 is favorable.
At first I hooked the antenna up by simply putting it on a tall pole, propped it up so that it would not fall, pointed it in the right direction, ran a 25' piece of coax cable to our main television by simply running the coax through the an open window. Did my channel scan on my television and I had reception for 70 channels. I was delighted!!!
That is when I called and canceled our cable company.
NOW . . .
I have two televisions (family room and master bedroom). The family room tv is approximately 18 feet from the antenna and the master bedroom tv is approximately 70 feet from the antenna.
WHAT is the best way to run my coax cables?
WHERE should I put my splitter?
I have noticed that my signal strength is significantly better in the day than at night. Is that normal???
If you can give my any wisdom that would be very appreciated.
Jonah is offline   Reply With Quote
