Old 27-Feb-2012, 4:52 PM   #22
MisterMe
OK. There are three obvious problems here. The first is that Costco is charging $10 over Winegard's price for the FV-HD30. The second is that you have chosen an antenna that is better for line-of-sight locations whereas you have a mountain between the transmission towers and your home. You have chosen a J-mount mast which will probably limit your antenna height to 15-20 feet whereas you need to mount your antenna as high as you can get it.
The FV-HD30 is a good antenna, but it is not a good antenna for you.
MisterMe is offline   Reply With Quote
