False Alarm
Thanks for the reply but, I realized my stupid error.
I had the lead hooked up to the wrong connector on my rotor.
I put it on the correct rotor connection and capped the other one.
I still had a poor signal on a couple of channels and fixed that, as well, by eliminating a useless "run"...I had run the wall RG6 output to the dvd player in and then out to the TV input. That wasn't needed at all and, when I connected the wall outlet DIRECTLY to the TV antenna input, I picked up additional signal strength and now get all of my channels with no pixelation and no drop outs. Thanks again.
Winegard HD7084P antenna
ProBrand Int'l RTR100 rotor
Winegard Boost Pre-Amp
Viewsonics VSMA 601C-10R Amp
Samsung 55UH8500FXZA
