Old 26-Feb-2012, 4:39 AM   #10
phone man
Originally Posted by Mortech View Post
I played around with the antenna position and I was able to get NBC on and off depending on the time of day/weather. So I guess this antenna is not bad if it is able to pick stations 85 miles away. My question is would the Antennas Direct preamp CPA-19 suggested by Electron work with my Philips Antenna? I was thinking I'll try adding a preamp first before trying a different antenna.
Mortech
Mortech, No harm in trying a preamp with the Phillips antenna but a preamp can't amplify a signal it doesn't have. Considering what you're trying to achieve, having a larger antenna with more gain gathering all the signal it can and then if necessary, amplify that signal, makes more sense than trying to boost a weaker signal.
phone man is offline   Reply With Quote
