Thread: TV Reception
Old 15-Jul-2010, 9:16 PM   #6
Smile Reception
This suggestion , install a winegard HD 7084P antenna pointed at channel 19. This All channel antenna will also pick up PBS 5 main transmitter. . If the coax wiring is a mess , clean it up. Install a three way splitter and have single and seperate runs of RG-6 coax to each Tv location. Install the 3 way splitter in a place that is easy to get at , do not put the 3 way splitter in a monkey swinging , death defying place. The >>StartMAPS<< part of tvfool shows the locations of the television transmitters. Install all this and see what the signal levels are at tv locations , then you will know if a antenna amplifier is needed.
