Old 25-Feb-2012, 5:21 PM   #14
pnguyen
Originally Posted by Electron View Post
If I lived at your location this is what I would install. For ease of use for receiving Digital Tv Stations/Channels I would install a Winegard HD7082P antenna with a Antennas Direct CPA-19 preamp aimed at about 40 degree magnetic compass for the Canada Digital Tv stations/channels. . And a Winegard HD7698P antenna with a CPA-19 preamp aimed at about 160 degree magnetic compass for the American Digital Tv stations/channels. The 2 antenna systems will have separate coaxes all the way to the location of the Tv. The 2 separate antenna coax systems will be connected to the inputs of a Remote Control A/B antenna switch and the output will be connected to the Tv. This set up is the easy life , push the buttons on the hand held remote control of the A/B antenna switch and change from one antenna to the other. No waiting for the antenna to rotate. Buy every thing at , http://www.saveandreplay.com , on line or go into the store.
Now I remember the set up on the antenna mast when it was dismantled (from previous home's owner): the big Yagi on top, with a smaller Yagi underneath (probably UHF range). The big one facing South, the smaller one facing North for the Can channels.
I could set them up the same way, just have to know how to wire the cables up to the pre-amp and down to the TV.
pnguyen is offline   Reply With Quote
