Old 25-Feb-2012, 8:37 AM   #13
Electron
Tv antennas and Tv reception
Ok it is fun to play 'what if' here at tvfool. If the Tv stations/channels stay the same in the future , all UHF digital channels , 14 thru 51 UHF , to the south east. Then use the same DB4e UHF antenna pointed at about 145 degree magnetic compass. Use a Channel Master CM7777 preamp with the DB4e antenna connected to the UHF input of the CM7777. Also there is digital Tv station that is just on positive side of the edge of being able to receive , WVBK-CA digital 2 in the VHF low band of channels 2 thru 6. The programing is , http://www.wvbktv.com , http://en.wikipedia.org/wiki/WVBK , The Outdoor Channel. . Install and connect a Winegard HD5030 channels 2 thru 13 antenna and connect to the VHF input of the CM7777 preamplifier. . If WVBK is not received then the HD5030 antenna can be turned to receive WMUR-TV 9 ABC at about 58 degree magnetic compass. The antennas will be mounted no lower then 40 feet above the ground. And if need to go higher then that is Ok. The Tv transmissions will get stronger if need to get above trees. Trees in full leaf do a good job of absorbing UHF transmissions. Here are some places to buy antennas and etc. http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.solidsignal.com , http://www.amazon.com http://www.starkelectronic.com , http://www.3starinc.com. Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
