Old 25-Feb-2012, 6:08 AM   #10
LOTL
More over thinking...
O.K. here is another what if. As i mentioned in my first post, we plan on selling this house and moving up to my house when it sells.
My property has very tall pine trees on either side. I have seen neighbors locate their satellite dishes away from tree coverage and run coax back to their house. (would be about a 100' run in my case)
I suspect that would be something i might have to do to get adequate reception (if in fact that direction is where the antenna needs to be pointed)
Heres my TVFool report for that location:
The other house
Would the DB4e still be the antenna of choice for that location with the possible use of a pre-amp? Or should i just worry about my present location and revisit the issue 2-3 years from now?
Thanks for the link to the tripod, i looked at a stand on Antenna Directs website and i believe it has the same dimensions as some of my speaker stands i use for DJ'ing. I have a couple old stands that i dont use anymore and it looks like one of them would do the trick.
LOTL is offline   Reply With Quote
