Old 25-Feb-2012, 2:56 AM   #5
MisterMe
Originally Posted by LOTL View Post
Would i need to take into consideration the elevation or angle of the antenna or does that only pertain to Satellite dish placement?
Don't overthink this. Electron has given you excellent advice. The parabolic reflecting dish for a satellite antenna is required because it is designed to receive extremely weak signals. You can receive most of your Boston stations with a set of rabbit ears and a UHF loop.
Dont Multi-Directional antennas have less range than directional antennas and arent they subject to more interference?
Yes. However, this is an issue with weak signals. Electron has recommended antennas that are more than up to the task of providing stable signals to your TV.
Im assuming a Directional antenna would require the need for a rotor of some kind to get the best signal from some of the stations. I take it that seeing as how the azimuth of a lot of the stations are around 117 degrees, that i wouldnt have to move it much. This is all new to me and im learning as i go.
Electron, why 145 degrees?
The 145° direction is a good compromise direction that will ensure that you receive ample signal strength from Boston while allowing you to receive weaker signals from New Hampshire.
MisterMe is offline   Reply With Quote
