Old 24-Feb-2012, 11:17 PM   #19
MisterMe
Originally Posted by soundbuild View Post
... Now I'm only getting 4 KOMO...is the antenna too big? The new antenna is hooked directly to the tv with no amp. Would raising the mast make any difference?
thanks
I see nothing wrong with your antenna, per se. The fact that you are receiving only KOMO leads me to suspect that the antenna is either misdirected or that it has a bad cable connection to your TV.
As a first measure, redo your channel scan. Be sure to scan for the AIR or ANT channels.
