Old 24-Feb-2012, 8:29 PM   #9
pnguyen
Originally Posted by Electron View Post
As an example here is a matching transformer that will most likley connect to the antenna. http://www.thesource.ca/estore/produ...roduct=1501140 . Use new RG-6 coax outside. And any where else that the coax might be less then good. Aim the antenna that you have at about 40 degrees magnetic compass for the Canada digital tv stations. . Then aim the antenna at about 160 degree magnetic compass for the American Tv stations/channels , WWNY-DT 7 CBS and FOX , WPBS-DT 41 PBS , WWIT-DT 21 ABC and CW . What is the reception like for the Canada and American Tv stations?? Remember the tv , Must Scan for the Digital Broadcast Tv Channels. Sometimes called the , ' Air Channels' or 'Antenna Channels'. Do Not scan for cable tv channels.
Thanks for the link to the transformer, a balun would be my next thing to worry about.
I'm settling down to the idea of re-using the old Yagi as I think my area (and local cities) didn't go to Digital too much during the last Aug 31st deadline, and wouldn't for a long period, according to CRTC's website. Some low VHF stations will still be there...
The old set up had the pre-amp with it. I'll have to decide if I want a new one.
pnguyen is offline   Reply With Quote
