24-Feb-2012, 4:50 PM
#19
Originally Posted by phone man
When I said "spoil it", I meant it would spoil the use of a preamp, not TV reception in general. Not being able to use a preamp could mean the difference in a weak channel that drops out frequently or one that has some margin above drop outs and can be viewed most of the time.
About the pending broadcast tower. I would try to find out what pending actually means in this case. Is it a for sure situation or does it just mean they have applied for and have plans for a tower sometime in the future, maybe years from now if ever.
The only difference in cost would be whether or not you have the preamp, $30 and up depending on what you get. The rest of the set up is the same.
Ah OK and thanks.
