Old 24-Feb-2012, 6:51 AM   #2
Electron
Tv antennas and Tv reception
Yes install the CM3020 antenna above the roof aimed at about 325 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some examples of roof mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. If you choose to buy the ronard mounts , type the word ronard in the in the search box of http://www.solidsignal.com , or buy from ronard. The Tv transmissions are Strong and will supply signal to , one , two Tv's with a simple common 2 way splitter with No antenna amplifier. How many Tv's are/will be connected?? If you have never seen the crystal clear digital pictures of Digital Broadcast Television then you are in for a very pleasant surprise. Remember the Tv Must Scan for Digital Broadcast Television Channels , some times called the , 'Air Channels' or 'Antenna Channels' because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna. Do Not scan for cable channels. If you also have streaming internet with Roku or Boxee internet receivers then by-by to cable and satellite.
