Old 22-Feb-2012, 2:59 AM   #13
phone man
Originally Posted by Electron View Post
I see no CBS or PBS tv stations at 327 degree magnetic compass , there are CBS and PBS stations at about 133 degree magnetic compass. So 2 antennas will need to be installed. The first antenna is a Winegard HD7082P antenna aimed at about 327 degree magnetic compass. The second antenna is a Winegard HD7698P antenna aimed at about 133 degree magnetic compass. I do not recommend a preamp for either antenna because UHF channel 23 at 9 degrees magnetic compass is a Very Strong signal and will likley overload a preamp and be the cause of bad or no reception of some channels.
I like your dedicated two antenna solution or Tower Guy's separate VHF, UHF combined into a preamp along with a rotator to turn and pick up CBS, NBC, PBS and maybe even CW from San Diego.
But, I must be missing something. I don't see the strong UHF channel you mentioned at 9 degrees. This guy is gonna need a preamp, no?
phone man is offline   Reply With Quote
