Old 21-Feb-2012, 9:58 PM   #1
pnguyen
What antenna to set up?
Hi,
New member here, would like to get some help with setting up antenna at my place.
This is my tvfool report:
http://www.tvfool.com/?option=com_wr...0b86456bfde9c6
My current antenna is a Yagi one, probably 12' long, 6'+ wide; my guess is a VHF/UHF. It's very heavy, and look scary with strong wind.
The antenna is about 30' above ground. The connections are probably all rust up, so no station are received.
Before I set thing up again, just wondering:
* Would an 8 bay bow tie works for most of the stations in pink? or I need to use the old Yagi again?
* If it's useful, I can install a rotator with the 8-bay; not with the old Yagi.
* Would a 8-bay Digiwave work as good as Channel Master? It's cheaper in my town.
* I'd like to avoid a pre-amp if it's possible?
Any other recommendations would be appreciated.
Thanks.
pnguyen is offline   Reply With Quote
