When you ask about reception of channel 6, I have to presume you're referring to real channel 23, XETV-DT, a CW affiliate.
A 4-bay panel antenna such as the Antennacraft U4000 aimed at about 150° should cover signals broadcast on UHF.
You may need to add a high band VHF antenna such as the Antennacraft Y5713 aimed at about 275° to make the ABC and CBS signals reliable.
The two antennas can be combined into a common down-lead using a UVSJ.
