Originally Posted by nachotime
No splitters are planned/needed for now, although it's conceivable we may add one later.
The main electrical service ground is in the basement and the antennae will be in the attic (approximately 15-20' apart). It seems my choices are a long, heavy gauge ground wire to the basement or running the coax down to a grounding block in the basement and then over to the TV. I'd like to avoid the second option as it's much easier to use a single coax cable and drop it down to the TV from above.
Thank you for the advice.
... until you run additional cable to other sets???
I'm not standing there looking at your exact situation, so you're better able to judge if to start with, a run to a future splitter location in the basement makes sense.
