No splitters are planned/needed for now, although it's conceivable we may add one later.
The main electrical service ground is in the basement and the antennae will be in the attic (approximately 15-20' apart). It seems my choices are a long, heavy gauge ground wire to the basement or running the coax down to a grounding block in the basement and then over to the TV. I'd like to avoid the second option as it's much easier to use a single coax cable and drop it down to the TV from above.
Thank you for the advice.
