Many thanks for the reply Electron.
There's nothing in the roof or framing that would prevent the Winegard antennae you've recommended. I'm about to place an order from a site (Parts Express) which carries the HD-7697, would that one work as well?
Regarding grounding the coax, is the coax surge protector sufficient or should I use a coax grounding block in the attic and run a ground wire?
Reason: removed reference to spam-bot
