Tv antennas and Tv reception
Mounting a antenna above the roof is better then in the attic , in the attic tv signals will be reduced of signal strength some and many attics have metal duct work and heating and airconditioning units in the attic that will be close to the antenna and disrupt reception. If the roofing is wood with standard composition shingles and no foil backed insulation. And you think that the antenna will fit in the attic pointed in the correct direction then Yes give it a try. I am doing my best to get you as many channels as possible without compromises. And Yes there are also advantages to putting a antenna in the attic , the antenna will last forever and it is not as dangerous as climbing on the roof.
