					Originally Posted by  dann
				Thank you, you think Antennas Direct CPA19 is better than Winegard HDP-269?
 I have no experience with the Winegard preamp.  I'm using a CPA-19, recommended by members of this forum for it's resistance to overload.  My strongest channel is 36 NM(db) and I have no overload issues.
Your strongest station is 56 NM(db)!  You might want to email Steve at Antennas Direct tech support, include a link to your TVfool report and see what he thinks about using a  CPA-19 preamp.  He could also give you good input about the C2V and your particular reception needs.
Steve was very helpful when I had a problem with my preamp. At his direction I ran a couple quick tests to isolate the problem and they sent out a replacement that day.  They do stand behind their products.
