The antenna Electron recommends should be fine. It covers all VHF and UHF stations available to you. The other good thing about the C2V is it's wide beam which may allow you to get by with one antenna aimed down the middle as Electron suggests.
I was thinking about an antenna with more gain but then it would also have a narrower beam so the C2V may be a very good single antenna solution. I think your aim will have to favor Burlington though.
You're in a fortunate spot where reception from 81 miles away is possible due to the elevation of the broadcast towers in Vermont. If you haven't already, click on any channel on your TVfool report and it will show you the signal strength and topography between the broadcast tower and your location.
How many TV's will be connected and how far are they from the antenna?
