Tv antennas and Tv reception
Yes , connect wire A to wire D to the cable modem. You understand what needs to be done. And yes use the splitter and other coaxes to distribute the antenna reception through out the house. The reason I go into the long explaination is because in the past , question askers , have been determined ( and I mean determined !!!! ) to connect the tv antenna to the active cable system.
