Old 19-Feb-2012, 2:21 AM   #6
dann
Originally Posted by Electron View Post
For reception of the Canada and American Tv stations digital channels. Install a , Antennas Direct C2V Complete , above the roof aimed at about 125 degree magnetic compass. Use a Winegard HDP-269 preamplifier. http://www.saveandreplay.com. SaveandReplay has different types of antenna mounts , tripod mounts , eave mounts , chimney mounts. The HDP-269 is a high input preamp that will not over load from the higher strength tv signals. The Cm7777 will likley over load and be the cause of bad tv reception or no tv reception on some channels.
Thank you, you think Antennas Direct CPA19 is better than Winegard HDP-269?
dann is offline   Reply With Quote
