					Originally Posted by  phone man
				Check your TVfool report for "real" channel numbers.  The Digiwave antenna specs indicate it's best at channels 21-69.  If you wish to receive lower channels, you'll need a different antenna.
I think you have plenty of signal strength,  no preamp should be necessary.
 you are right, i miss that point, which antenna do you recommend for me?
tks.
