Old 18-Feb-2012, 3:30 PM   #11
No static at all
No static at all's Avatar
Any chance you could fit this antenna in your space? After reading the reviews on the Mohu, I suspect you may just need a different/better antenna if the attenuator doesn't help.
Overload from towers 4 miles away is rare unless some type of amplification is used. I use the antennas in the photo to the left with even stronger signals & see no overload whatsoever.
