Old 10-Jan-2010, 7:28 AM   #7
OTAMAN2010
Congressional Law
Originally Posted by mtownsend View Post
I don't know how big your attic is, but the antenna is about 7 feet long and 4 feet wide. You'd get most of your channels at a compass heading 301 degrees), so you''ll need enough room to rotate it to that position.
Furthermore, you'll need to try and keep the antenna clear of any objects (ducts, pipes, metal structures, etc.), so it might require a bit of trial and error to find the optimum location within the attic that gives you the best reception.
BTW, if you weren't already aware of this, the FCC has an over-the-air reception devices rule (http://www.fcc.gov/mb/facts/otard.html). I understand the desire to minimize friction with your HOA, but in this particular case, you have the federal law on your side. It essentially boils down to saying that everyone has the right to install a reasonable antenna for OTA reception, and no landlord, HOA, city, county, or state law can prevent you from exercising that right. There are a few exceptions to this rule, so please read the document carefully.
Sometimes, just knowing that you have the law on your side is enough to help work out a reasonable compromise that everyone can live with.
Mtownsend is right about the law. Just explain to HOA, Did you sign a contract with HOA. You can always have it retrive. But the Congressional Telecommunications Act of 1996 give you the right to put up a antenna even on apartment buildings. Just as the Congressional law Art 4 give you the right to bear a fire arm. Speak up man don't be afraid. If its' you house you pay the bill Every month, not them.
I had a directional antenna and it was great for the direction I pointed it, 25 channels I had to rotate it for other channels. I later purchased the channel master 4228 a multi direction and received over 40 channels requiring no adjustments. VHF was weak until I broke of some rabbit ears and slide one on each side, and presto VHF was good. There are others DB2 amd many more. Radio Shack has a good omni derectional antenna with a built in amp. Flat round type not as noticeable.
Just some ideals. Hope it help.
The 4228
OTAMAN2010 is offline   Reply With Quote
