Old 13-Jul-2010, 6:50 PM   #1
rockstar45
Antenna selection help
Hi I’m new.
I have been investigation the possibility of picking up OTA signals in my new house. Please see my TV Fool Results here http://www.tvfool.com/?option=com_wr...9fbe99721c098d
I have been playing with a cheap Philips rabbit ear and loop antenna and have managed to pick up quite a fetw channels. With the antenna on my second floor I can pick up WNYT and WMHT which are listed in red and and a faint WRGB signal. I can also pick up a faint WCWN signal if I hang it outside.
I think it is time for a larger antenna. I would like to mount it in the attic pointing through the gable which has vinyl siding covering it. It is in a perfect westward direction. I would mount it on my roof but it is slate and I have too many other obstructions.
So, what antenna would you recommend? Would an antenna direct DB4/8 work in my situation? What would I do about VHF? I assume I would need a preamp since my rabbit ears has one.
Thanks for your help.
rockstar45 is offline   Reply With Quote
