Tv antennas and Tv reception
If the roof and framing are wood with standard composition shingles and no metal foil backed insulation. Then install a Winegard HD 7696P antenna aimed at about 166 degree magnetic compass in the attic , no ground wire will be needed in the attic. Grounding the coax will direct interfering signals to ground , so thats a good idea. No preamp will be used , the tv stations/channels in the green reception zone are very strong.
