Old 17-Feb-2012, 12:07 AM   #2
Electron
Tv antennas and Tv reception
The tv transmissions are weak to begin with , having the GY-Ant02 antenna in the attic further reduces the signal strength. The mounting bracket is the back of the antenna , aim the front of the GY-Ant02 antenna at about 215 degree magnetic compass in the attic. And extended the rods out. If reception is still not very good , the GY-Ant02 antenna will need to be mounted above the roof. If the GY-Ant02 antenna is mounted above the roof then aim the antenna at about 193 degree magnetic compass.
