Old 16-Feb-2012, 8:07 PM   #4
Electron
Tv antennas and Tv reception
Ok 50 feet it is , at 35 feet and 25 feet WKBN and WFMJ drop off the radar. Install a Winegard HD9095P antenna aimed at about 23 degree magnetic compass and a Winegard YA1713 antenna aimed at about 70 degree magnetic compass. The two antennas are connected together with a UVSJ = UHF/VHF Separator Joiner. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are the tv stations/channels that will be received , WNEO-DT 45 PBS , WKBN-TV 41 CBS and FOX , WFMJ-TV 20 NBC and CW , WTOV-TV 9 NBC and Me-TV , WTRF-DT 7 CBS and FOX and MyNetwork and ABC , WOUC-DT 35 PBS. This set up will supply signal to one tv with no amplifier. If two tv's are connected use a Channel Master CM3412 two way distribution amplifier. If 3 or 4 tv's are connected use a CM 3414 four way distribution amplifier. Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. Here are places to buy antennas and etc. , http://www.channelmasterstore.com , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com. Type ronard in the SolidSignal search box or buy from ronard.
