^^^I'm still on the fence on this. I guess it will ultimately come down to which configuration will cost less. Clearly I can achieve my objective without the rotor though. I am able to DX from here without rotating the antenna all that much but yes, you are correct I would have the potential to receive channels from the other directions where I don't obtain any kind of "local" signals.
Which rotor are you using? Is it reliable? You have just about the same amount of antennas on your mast as I do. It sounds like the Alliance rotor that TB's recommends will be the best, most cost effective solution for me that will handle the load that I plan.
