Old 14-Feb-2012, 7:20 AM   #3
Electron
Tv antennas and Tv reception
All of the tv stations/channels you will like to receive will be received and more , even WOSU 38 PBS and WWHO 46 CW. . When the leaves are on the trees and if channels are lost , the antenna can be mounted higher. Or if the trees are close to the house and not much trees are beyond , the antenna can be put on the other side of the trees. Or if the trees are 'some distance' from the house then the trees will not reduce the signal much.
