Old 13-Feb-2012, 9:20 PM   #1
beerdini
Replaced Antenna Lost Channels
This past summer I replaced the roof antenna of over 30 years in the home that I grew up in. The main problem that I had was that the antenna rotor seized up due to rust and lack of use and after a bad storm came through it turned the antenna so that we couldn't point it back to where it needed to be.
I replaced the antenna and rotor motor. When I first replaced the equipment I put the antenna at the top of the pole that it came with and mounted it in the rotor motor which I had fixed to the top of the old tripod. I got most of my channels plus the newer digital ones, but after reading that the rotor motor was only rated for a 6ft pole I cut the mast to 6 just under 6ft from the previous 10ft.
After reconnecting everything I've found that I lost a handful of my channels, and I lost the "local" CBS affiliate that used to come in nice in clear with the previous antenna prior to the digital conversion. The house is located in the 49445 ZIP code, and the CBS affiliate is WWMT out of Kalamazoo, MI which is about 60 miles away. I did purchase a signal amplifier and ran brand new cabling from the antenna to the amp, and new cables from the amp to the main TV, there are no splitters in the line at all.
Is there anything that I can try to do to get this channel to come in? It is showing with a 2edge connection when I run the data on the TVFool website. Thanks!
beerdini is offline   Reply With Quote
